Bootloader implementation on cortex-m3
Note: This was originally posted on 21st February 2012 at http://forums.arm.com
Hey, I'm working on a project on a Atmel's SAM3S4C, and I started to create a seperate bootloader for it.
The bootloader is a seperate project in IAR.
I'm sucessfully flushing the application code into the internal flash, however, when I try to jump to the application from the bootloader, using the Vector interrupt table re-allocation, the code just won't start.
The bootloader is placed at 0x00400000 - 0x00401FFF
and it's vector table is at 0x00400000.
The application is located at 0x00402000 - 0x0043FFFF
and it's vector table is at 0x00402000
This is the code for jumping to the application from the bootloader is:
Code:
int * address = ( int * ) 0x00402004; //pointer to reset handler of application
__set_MSP ( * ( int * ) 0x00402000 ); //set the stack pointer to that of the application
* ( int * ) 0xE000ED08 = 0x00402000; // VTOR: set the vector table to that of the app
( ( void ( * ) () ) ( *address ) ) (); // pointer recast as function pointer and the dereferenced/called
    while ( 1 )[/size]
        { }; //you application was never executed
can anyone help me with this ?
