Synchronization in SMP-system WFE/SEV DMB/DSB
Note: This was originally posted on 31st October 2011 at http://forums.arm.com
Hi, I'm trying to synchronize a Cortex-A9 MPCore in SMP mode, but am failing this far. I tried to figure out how to use the barriers correctly, but apparently I'm missing something. The code looks basically like this:
CPU0:
   str   r0, [ADDR]
   dsb
   sev
CPU1:
   wfe
   dsb    @ I added this later, doesn't seem to have any effect
   ldr   r0, [ADDR]
The problem is, CPU1 reads stale data (at least I consider it stale). I'm pretty sure it's some coherency problem, since the code works as expected with caches disabled.
I already checked:
- the MMU is enabled
- SMP bit is set in aux-ctrl
- I'm accessing fully-cacheable memory
- The SCU reports two CPUs taking part in coherent SMP.
Any hints are appreciated.
