Division with NEON
Note: This was originally posted on 30th September 2011 at http://forums.arm.com
Hi.
I have 4 unsigned 16bit values into a Dn register (or 8 into a Qn register)
[v1] [v2] [v3] [v4]
I'm looking for the code to finaly have
[65536 / v1] [65536 / v2] [65536 / v3] [65536 / v4]
into another (or the same) Dn (or Qn) register...
Thank's
Etienne
  • Note: This was originally posted on 26th September 2012 at http://forums.arm.com
    I ended up on this discussion while looking for a way to use integer division into ARM NEON registers.
    My problem is similar, the only difference is that I need to work with signed 16 bit integers instead of unsigned ones.
    Is there any way to do this? Also, I don't understand how the original uint16 bit problem of the post has been solved converting uint32 to float32. How can this be possible with the case of the uint16x8_t bit Qn register?
    Thanks,
    Francesco
    Thanks,
    Francesco
