Hi. I've installed the Community Edition of DS-5 v5.26.2 on a Windows 7 machine. My target is the latest Beaglebone Black Wireless. I've tried several Linaro toolchains. With each toolchain, my attempt to compile the initial Hello World program provided by DS-5 fails. For some of the toolchains, even the macro expression EXIT_SUCCESS is undefined (I substiute 0 for it); for others, it is defined. The failure is always the same. I've tried toolchain version 6.1.1 -- specifically
gcc-linaro-6.2.1-2016.11-i686-mingw32_arm-linux-gnueabihf
-- as well as versions 4.9.4 and 6.2.1.
The results here are for version 4.9.4, but it's virtually the same result for all three.
The Problems window shows
Description Resource Path Location Typemake: *** [HW621] Error 1 HW621 C/C++ Problemrecipe for target 'HW621' failed makefile /HW621/Debug line 30 C/C++ Problemsyntax error HW621 line 1, external location: c:\local\linaro49\gcc-linaro-4.9-2016.02-i686-mingw32_arm-linux-gnueabihf\arm-linux-gnueabihf\bin\ld.exe:c:\local\linaro49\gcc-linaro-4.9-2016.02-i686-mingw32_arm-linux-gnueabihf\arm-linux-gnueabihf\libc\lib\libc.so.6 C/C++ Problem
The Console window shows:
17:25:06 **** Build of configuration Debug for project HW621 ****make all 'Building file: ../src/HW621.c''Invoking: GCC C Compiler 4.9.4 [arm-linux-gnueabihf]'arm-linux-gnueabihf-gcc.exe -O0 -g -Wall -c -fmessage-length=0 -MMD -MP -MF"src/HW621.d" -MT"src/HW621.o" -o "src/HW621.o" "../src/HW621.c"'Finished building: ../src/HW621.c'' ''Building target: HW621''Invoking: GCC C Linker 4.9.4 [arm-linux-gnueabihf]'arm-linux-gnueabihf-gcc.exe -o "HW621" ./src/HW621.o c:/local/linaro49/gcc-linaro-4.9-2016.02-i686-mingw32_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/../../../../arm-linux-gnueabihf/bin/ld.exe:c:\local\linaro49\gcc-linaro-4.9-2016.02-i686-mingw32_arm-linux-gnueabihf\bin\../arm-linux-gnueabihf/libc/lib/libc.so.6: file format not recognized; treating as linker scriptc:/local/linaro49/gcc-linaro-4.9-2016.02-i686-mingw32_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/4.9.4/../../../../arm-linux-gnueabihf/bin/ld.exe:c:\local\linaro49\gcc-linaro-4.9-2016.02-i686-mingw32_arm-linux-gnueabihf\bin\../arm-linux-gnueabihf/libc/lib/libc.so.6:1: syntax errorcollect2.exe: error: ld returned 1 exit statusmake: *** [HW621] Error 1makefile:30: recipe for target 'HW621' failed
17:25:08 Build Finished (took 2s.44ms)
PLEASE can someone help me? I've hacked around this for three or four days, installing and uninstalling DS-5 and various toolchains. I've fiddled with my PATH variables, installed GNU make in a directory at the front of the PATH (to hide the make program associated with Delphi7 that was already there), etc. I'm stuck!
Thanks,
Richard
.. and the solution on the 7-Zip bug tracker seems to be to elevate permissions for 7-Zip to alleviate the problem, which seems simpler for extracting a single archive than other solutions such as Group Policy. Could you "Run As Administrator" your archive program (such as 7-Zip) and re-extract GCC and try again?
