Cortex-R4F : need explanations about some PMU events
Note: This was originally posted on 29th July 2011 at http://forums.arm.com
I am using a Cortex-R4F (TMS570), and I used PMU to count the number of "Instruction architecturally executed" and "Dual-issued pair of instructions architecturally executed" (§6.1 of DDI0363E) in order to benchmark that component, and I get a strange result : I built a test code with 4096 instructions (in fact, a little bit more before and after the PMU is started/stopped), and I obtained :
- in ARM mode :
     3083 Instruction architecturally executed
     2048 Dual-issued pair of instructions architecturally executed
- in Thumb mode :
     4015 Instruction architecturally executed
Please, could someone explain why the number of Instruction architecturally executed is not the same in both modes ?
And more important for me : how can I count the real number of instructions of any code ?
Thanks a lot
Best regards
Christophe
  • Note: This was originally posted on 20th February 2012 at http://forums.arm.com
    Hi all,
    Does someone have an idea ? I really can not figure out why the PMU count is wrong...
    Thanks a lot
    Best regards
    Christophe
  • Note: This was originally posted on 22nd February 2012 at http://forums.arm.com
    Thanks for your answer. I am sorry, I realize I was indistinct...
    Of course, my test code is written in assembler :
    movs r0, #1
      nop
      movs r1, #2
      nop
    movs r2, #3
      nop
    preceded with a strict directive for compiling in ARM or Thumb mode.
    Best regards
    Christophe
    You said that it should be 4096, how do you know this? What are you writing the code in?  C will typically compile to more Thumb instructions than ARM instructions*, so what you've seen isn't necessarily wrong.
    * There are cases where ARM instructions are more flexible than Thumb instructions.  So the compiler can use one ARM instr or two Thumb instrs.  This is less common with Thumb-2, but there are still some instances.
