Fast Model: Best way to model unaligned multiple register read/write
I am looking for a good method to implement multiple unaligned register access using LISA+ in Fast Model. Can you recommend a good way to do this?
For example, below are the register declaration:
REGISTER { reg_number(0x0000), bitwidth(16), reset_value(0x3836) } REG16_000;  //address 0x00
REGISTER { reg_number(0x0002), bitwidth(8),  reset_value(0x1)    } REG8_002;  //address 0x02
REGISTER { reg_number(0x0003), bitwidth(8),  reset_value(0x0)    } REG8_003;  //address 0x03
And in the application we should be able to perform the following:
*((uint16_t *)0x20000000) = 0xAAAA;        //write to REG16_000
*((uint32_t *)0x20000000) = 0xAAAABBCC;     //write to REG16_000, REG8_002, REG8_003
*((uint8_t *)0x20000001) = 0xAA;            //write to second byte of REG16_000 only
I am relatively new to LISA and Fast Model. And all the examples in the shows aligned access to single registers (ie: access to single register at aligned address).
Thanks in advance
