Cortex NVIC interrupt level and pulse type by software?
Note: This was originally posted on 22nd July 2011 at http://forums.arm.com
I have read the ARM document about Cortex-M3 (or M0) and it say it can be used as level sensetive or pulse (edge) interrupt within the NVIC controller. The problem that it rather vague on how to do this, if this is done by software.
I fails to see any kind of register within the NVIC or such that control the type of the interrupt (to select edge or level by adjusting the register bits). So something must be done by software within handler but again it vague in this field.
It say I need to refer to chip vendor to establish if this is level or pulse type (for example LPC17xx), how they make it fixed, was is done by H/W outside Cortex module or configured by software to NVIC?
I like to hear anyone having a way to make it edge or level trigger interrupt by software if this is possible,. If so please demonstrate within the handler code (if this control it) that the make it detect for level or pulse.
If this is level detect, I can hold interrupt active which goes to handler and disable it, until restore by external code for which it re-execute the handler. This is what I'm trying to do as this is the way to check if the external signal remain in active state, but it will not work if this is pulse detect type.
I'm not talking about GPIO. .
