Hard Fault on cortex M3 NXP
Note: This was originally posted on 20th June 2011 at http://forums.arm.com
I've coded a small program to download in a usb memory some data acquired from the LPC1768 Cortex M3.
I use IAR EW to code and J-Link LITE to program/debug the code.
So, when I test my program with debugger connected (either in debug or release mode) it works fine.
When I program the micro and run it without the debugger connected I obtain an Hard Fault exception.
When I check the value of HFSR it return 0x80000000 -> DEBUGEVT = 1 ?
Why? Where is my fault?
Thanks.
Alessandro
