Hi,Is it possible to run a jython script from the command line? It sounds only ds scripts are supported . When invoking the debugger from comand line I would like to connect to a target, load a elf/axf file (this is the easy part) but also do some run/ add breakpoint, set and retrieve data with a jython script to handle all possibilities/ exceptions.thanksclaude
Hi, Thanks, but my question was badly formulated, I mean in fact can we launch jython script from the windows command or from a linux console?
For instance I can have
debugger --cdb-entry "..." --image "..." --script "my_script.ds"
But I would like to run directly a python/ jython script
jython my_Script.py from the console (windows or linux)
Sounds the highest API is my_debugger=Debugger()
which returns a handler on the already opened debugg session
I would like to have the possibily to invoke the debugger from a jython script
using a configuration DB, a image file and eventually a script.
But It seems there is no such APIs
regards claude
Given what you are trying to do, you might want to invoke DTSL directly via command-line executed .py scripts. More information about DTSL can be found at developer.arm.com/.../dtsl DS-5 comes with a few DTSL examples that you can run in Eclipse or via a command-prompt. The examples are at <DS-5 installation directory>\examples\DTSL_examples.zip
