Run jython scripts from command line
Is it possible to run a jython script from the command line? It sounds only ds scripts are supported . When invoking the debugger from comand line I would like to connect to a target, load a elf/axf file (this is the easy part) but also do some run/ add breakpoint, set and retrieve data with a jython script to handle all possibilities/ exceptions.
thanks
claude
