Problem disabling cache on ARM926ej-s
  • Note: This was originally posted on 16th March 2011 at http://forums.arm.com
    > Are you marking memory as write-back cacheable?
    Yes.
    > If so, you should be cleaning the D cache as well as invalidating it.
    disablecache: mrc p15, 0, r15, c7, c14, 3 @ test, clean and invalidate
                    bne disablecache
                    mov r0,#0                 @ drain write buffer
                    mcr p15, 0, r0, c7, c10, 4
    @@@@            mcr p15, 0, r0, c7, c6, 0    @ invalidate dcache
                    mrc p15, 0, r0, c1, c0, 0    @ Disable Icache(12), Dcache(2) and MMU(0)
                    bic r0, r0, #4096
                    bic r0, r0, #5
                    mcr p15, 0, r0, c1, c0, 0
                    mov pc,lr                 @ return to SWI handler
    Like this, in that order?
    > Is the memory flat mapped?
    Yes
  • Note: This was originally posted on 17th March 2011 at http://forums.arm.com
    Or maybe like this (please answer)
    disablecache:    mov r0,#0                 @ drain write buffer
               bne disablecache
               bic r0, r0, #4096
               bic r0, r0, #5
    What about those NOPs or delays I see in some sources after accessing CP15?
    I've copied (almost) this from linux, and it still doesn't work.
                    bne DisableCache
                    mov r0,#0
                    mcr p15, 0, r0, c7, c5, 0    @ invalidate I cache
                    mcr p15, 0, r0, c7, c10, 4      @ drain write buffer
                    bic r0, r0, #4096
                    bic r0, r0, #5
                    mov pc,lr
    Got it!
    "bne DisableCache" should be "bne disablecache"
    Are you marking memory as write-back cacheable?  If so, you should be cleaning the D cache as well as invalidating it.
