Pipeline Stage Read and Write
Note: This was originally posted on 5th March 2011 at http://forums.arm.com
I'm still trying to understand the cycle table of the cortex A8.
Most of the test I've made suppose this:
- source register are needed at the beginning of the stage
- destination register are released at the end of the stage.
With those rules it's seem's that result are quite good.
For example, this code take 3 cycles
    add   r5, r5, #1
    mov   r6, r5
because ADD release r5 on the end of stage 2 while MOV need it at the beginning of stage 1
That 's work and that's real cycle execution timing.
But I've a problem with the MLA shortcuts
    mul   r4, r5, r4
    mla   r0, r6, r7, r4
the MUL should release R4 at the end of stage 5 (of the second cycle of the MUL)
the MLA need r4 at the beginning of the stage 4 (due to MLA shortcut).
So the code should take 5 cycles, but in fact It takes only 4 cycles.
Is it possible that r4 is only needed at the beginning of the stage 4 of the second cycle of the MLA ???
Or may be the forwarding is done at the end of the stage 4. So I could suppose this is the same thing as the beginning of the stage 5 !
That could explain the missing cycle.
  • Note: This was originally posted on 23rd March 2011 at http://forums.arm.com
    A multiply that is followed by a MAC with a dependency on the accumulator, Rn register, triggers a special accumulator
    forwarding. This enables both instructions to issue back-to-back because Rn is required as a source in E4. If this accumulator
    forwarding is not used, Rn is required in E2.
