Global variable alignment
Note: This was originally posted on 13th January 2011 at http://forums.arm.com
I am working with RealView Compilation Tools v2.1.  I need to align a static global variable on a 16-byte boundary.  In the 'Compiler and Libraries Guide' document, section 3.1.3, the __align(n) keyword is explained.  It is not clear to me if n=16 is allowed for a static global variable.  I have tried it and it appears to be working, but I would like to confirm it.
Best Regards,
  Miguel
  • Note: This was originally posted on 17th January 2011 at http://forums.arm.com
    I have not received any answers, can someone help me on this?
    Regards,
      Miguel
  • Note: This was originally posted on 19th January 2011 at http://forums.arm.com
    The point is that RVCT 2.1 says: '[font="Times-Roman"][size="2"]You can specify a power of two for the alignment boundary, however eight is the maximum for auto variables'.  As I understand, an 'auto' variable is the same as a 'local' variable, so it is not clear to me what is the limitation for global variables.
    Regards,
      Miguel[/size][/font]
    For RVCT 2.1 it is only specified to work for alignments of 1,2,4, or 8 - it is unclear what happens for alignments larger than this, although I suspect it is not guaranteed to do anything predictably.
    FYI - in newer tool releases (RVCT4.1) it will work for the following alignments of n:
    • For local variables, n can take the values 1, 2, 4, or 8.
    • For global variables, n can take any value up to 0x80000000 in powers of 2.
