VPf vector example
Note: This was originally posted on 5th January 2011 at http://forums.arm.com
Hi.
the cortex documentation speak about register bank for vector usage.
That's great, but I do not really understand what is a vector instruction (using those bank)
Does anybody can give me an example using the register bank and vpf vector instruction ?
Thank's
  • Note: This was originally posted on 19th January 2011 at http://forums.arm.com
    I'm agree with you.
    But this is the only usage I found for the bank register.
    NEON do not use the bank registrer.
    Most of NEON instruction can use all NEON registrer without any restriction.
    With the VFP architecture, the VFP registers were divided into 4 banks. So you had:
    Bank #0: S0-S7 and D0-D3
    Bank #1: S8-S15 and D4-D7
    Bank #2: S16-S23 and D8-D11
    Bank #3: S24-S31 and D12-D15
    When you set the VFP vector arity to greater than 1, Banks #1 through #3 were used for vector operations, while Bank #0 was reserved for scalar operations. That way, even if you had set the vector arity to say 4 and were performing operations on 32-bit floating point 4-vectors, you still could use registers S0-S7 for scalar 32-bit floating point operations without having to switch the VFP unit's vector arity back to 1.
    Of course, now that VFP is deprecated on ARMv7 based architectures such as Cortex, NEON is the way to go. VFP instructions with the arity set above 1 on ARMv7/NEON processors will perform much slower, so you should avoid using them on those platforms and use the NEON pipeline instead.
    Edit: There was another interesting property of register addressing when used in vector operations that I had forgotten to mention. The subsequent registers comprising a vector would wrap around on the register bank boundaries. So if you issued the following instruction when the vector arity was set to 4:
    fadds s16, s14, s20
    The first vector operand starting at register s14 would wrap around so that it would be {s14, s15, s8, s9}. It would be the equivalent of:
    s16 = s14 + s20
    s17 = s15 + s21
    s18 = s8 + s22
    s19 = s9 + s23
    You could exploit this trick to perform shuffling of vector components without additional instructions.
    I'm agree with you.
    fadds s16, s14, s20
    s16 = s14 + s20
    s17 = s15 + s21
    s18 = s8 + s22
    s19 = s9 + s23
