Linker warning
Note: This was originally posted on 22nd October 2010 at http://forums.arm.com
Hey all,
While linking my object files using armlink, I get the following warnings :-
Warning: L6221E: Execution region Region_3 with Execution range [0x0002c974,0x0002cc4c) overlaps with Execution region Region_6 with Load range [0x0002c978,0x00004304).
Warning: L6221E: Execution region Region_6 with Execution range [0x0002cc4c,0x00030f50) overlaps with Execution region Region_7 with Load range [0x00030c7c,0x00000664).
Warning: L6221E: Execution region Region_7 with Execution range [0x00030f50,0x000315b4) overlaps with Execution region Region_8 with Load range [0x000312e0,0x00000160).
Warning: L6221E: Execution region Region_7 with Execution range [0x00030f50,0x000315b4) overlaps with Execution region Region_9 with Load range [0x00031440,0x000089a0).
I am using a scatter file defined as followes:-
LOAD_REGION 0x00000000
Region_1 0x00000000 ABSOLUTE
Region_2 +0
Region_3 +0
Region_4 +0
Region_5 +0
Region_6 +0
Region_7 +0
Region_8 +0
Region_9 +0
Kindly guide me as to where I am going wrong.
Thanks and Regards
Abhinav Varma
  • Note: This was originally posted on 25th October 2010 at http://forums.arm.com
    Do some of Region_1 .. Region_8 have ZI sections?  These won't take up load region space and could cause the later load regions to "shift up".  Possibly RW compression could do the same.  Maybe you can move all of you ZI to the last region and all of your RW to the last or next-to-last?
