Compiler doesn't implement "Conditional Execution Instruction" (e.g. SUBS). Why ?
In the excellent textbook ARM System Developer's Guide: Designing and Optimizing System Software (Andrew N. Sloss, Dominic Symes, Chris Wright - Elsevier, 2004) there is example on the page 115:
int checksum_v6(int *data)
unsigned int i;
int sum=0;
for (i=64; i!=0; i--)
sum += *(data++);
return sum;
that is disassembled (according to authors) in the following code:
checksum_v6
     MOV r2,r0 ; r2 = data
     MOV r0,#0 ; sum = 0
     MOV r1,#0x40 ; i = 64
checksum_v6_loop
     LDR r3,[r2],#4 ; r3 = *(data++)
     SUBS r1,r1,#1 ; i-- and set flags
     ADD r0,r3,r0 ; sum += r3
     BNE checksum_v6_loop ; if (i!=0) goto loop
     MOV pc,r14 ; return sum
I reproduced this example, and what I've got this:
checksum_v6 PROC
        MOV      r2,r0
        MOV      r0,#0
        MOV      r1,#0x40
|L1.48|
        LDR      r3,[r2],#4
        ADD      r0,r0,r3
        SUB      r1,r1,#1
        CMP      r1,#0
        BNE      |L1.48|
        BX       lr
        ENDP
As you can state (highlighted in red) in my version of disassembly instead of one conditional execution instruction (that is more efficient) compiler placed 2 instructions: SUB and CMP.
I've tried with all optimization options but couldn't reproduce book authors disassembly.
Does exist some flag that regulates such kind of things ?
Thanks in advance.
Pavel
