out of store while compiling
Note: This was originally posted on 24th June 2010 at http://forums.arm.com
I got this error while compiling a large file.
Error: C3048U: out of store while compiling with -g. Allocation size was 20770816, system size is 653640852.
Is this due to compiler limitation?
How do you increase the allocation size?
Thanks,
-a
  • Note: This was originally posted on 28th June 2010 at http://forums.arm.com
    If you use a famous web search engine on "C3048U" you will find this [url="http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0496a/BABIBIBH.html"]Errors and Warnings[/url] page which discusses C3048U and which might help.
    Thanks for the reply.
    Before I posted the question, I actually went on that famous web search  B)  to find the solution.
    But, I thought there way a way to increase the allocation size.
    Thanks..
  • Note: This was originally posted on 30th June 2010 at http://forums.arm.com
    I think the allocation size is telling how many bytes armcc was trying to get when it ran out and the system size is how many it has allocated so far -- but the actual details may be different.
    I think you need to increase your virtual (or actual) memory somehow.  Or compile without -g or split the file up...
