DS-5 eclipse debug stuck at waitForTargetToStop
First I follow the DS-5 start demo and can debug my code correctly on the ARM FVP -> VE_Coretex_A9x1.
Then I follow the link to enable NEON and it needs to set CPU target in the build, the axf file has been built correctly but the debugger stops to work. The CA9_FVP hangs after connected to board. It shows waitForTargetToStop.
Connected to stopped target ARM FVP (Installed with DS-5) - VE_Cortex_A9x1 Execution stopped at: S:0x00000000 loadfile "S:\code\wireless\math_neon\Debug\math_neon.axf" S:0x00000000 DCI 0xe7ff0010 ; ? Undefined Loaded section ER_RO: S:0x80000000 ~ S:0x80002C0B (size 0x2C0C) Loaded section ER_RW: S:0x80002C0C ~ S:0x80002C1F (size 0x14) Entry point S:0x80000000 cd "C:\Users\fengxu\Documents\DS-5 Workspace" Semihosting server socket created at port 8001 Semihosting enabled automatically due to semihosting symbol detected in image 'math_neon.axf' Working directory "C:\Users\fengxu\Documents\DS-5 Workspace" set debug-from main start Starting target with image S:\code\wireless\math_neon\Debug\math_neon.axf Running from entry point wait
arm - DS-5 eclipse debug stuck at waitForTargetToStop - Stack Overflow
