Cycle count in cortex m3
Note: This was originally posted on 10th December 2009 at http://forums.arm.com
Hi all,
I am new to cortex m3...
For my application I need to calculate the number of cycles for a particular function....
I set the debug options as high optimization level and optimize for time....
How can I calculate the MIPS/cycles manually for a particular function.
Please suggest me a solution...
Thanks in advance.
Krish.
  • Note: This was originally posted on 11th December 2009 at http://forums.arm.com
    Hi Krish,
    I few things you need to do:
    1. Define the registers as "volatile", and "unsigned"
    2. Enable TRCENA bit in DEMCR (0xE000EDFC, bit 24) before using DWT
    3. You should use DWT's Cycle Count Register (0xE0001004) for timing measurement.
    The CPI counter is only 8-bit, and need to have trace support to detect the number of time it overflow.
    While the DWT Cycle Count Register is 32-bit.
    4. You need to enable the Cycle Count counter.
    So based on the code you have prepared, it can be modified to:
    int count = 0;
    volatile unsigned int *DWT_CYCCNT = (int *)0xE0001004; //address of the register
    volatile unsigned int *DWT_CONTROL = (int *)0xE0001000; //address of the register
    volatile unsigned int *SCB_DEMCR = (int *)0xE000EDFC; //address of the register
    *SCB_DEMCR = *SCB_DEMCR | 0x01000000;
    *DWT_CYCCNT = 0; // reset the counter
    *DWT_CONTROL = *DWT_CONTROL | 1 ; // enable the counter
    count = *DWT_CYCCNT;
    I haven't test this code in hardware but it should work.... :-)
    The ISSM might not have the detail model of debug components, so it is best to do the timing measurement on actual hardware, either on actual microcontroller or on our FPGA prototyping system.
    Note that if the debugger you are using is trying to use this counter at the same time (e.g. if you have got some sort of profiling feature turn on in your debug environment), you might find incorrect profiling result by doing this.
    regards,
    Joseph
    Hi Krish,
    int count = 0;
    regards,
    Joseph
