Prefetch Abort while calling __main
Note: This was originally posted on 22nd October 2009 at http://forums.arm.com
Hi All,
    I am calling "__main" instead of "main" in my code for ZI data initialization, for copying code to ram, and for arm library initialization. But, during my program execution I'm facing Prefetch abort. This happens in "__rt_lib_init" function. Can anybody explain the reason for this ?
    I solved it by adding the following code:
    EXPORT __rt_lib_init
    IMPORT main
    __rt_lib_init
    LDR R0, =main
    BX R0
   But why should I get Prefetch abort if I call "__rt_lib_init" ?
Note:
The arm core being used here is ARM7TDMI-S (no cache).
Compiler Options: --apcs /interwork --thumb -O2
Linker Options: --datacompressor off --callgraph
Thanks in advance,
Gopu.S
  • Note: This was originally posted on 22nd October 2009 at http://forums.arm.com
    I wouldn't suggest your work around as a long term solution.  :lol:
    If you are scattering loading, I would suspect that something in your scatter file is wrong.  Scatter loading occurs in __main() before the call to _rt_lib_init().  I suggest that you double check your scatter file and compare with your memory map.  You might also want to check if you stop before _rt_entry(), that memory contains what you expect it to.
    My Scatter File is a very simple one, and here it is
    FLASH_LOAD_REGION 0x20005000
        FLASH_EXECUTION_REGION 0x20005000  0x80000
            *sst230startup.o (INIT, +First)
            *(InRoot$$Sections)
        INTERNAL_SRAM           0x100
            *(+RW +ZI)
            *(+RO)
            *(STACK)
