Info required on Semihosting support for bare metal
I am  trying to get the prints through semihosting . Currently i followed the below steps
1. Created simple hello world application
2.Using DS5.23 eclipse with VF_Cortex_A9x4
3.Once connected to target, semihosting is auto enabled
Print messages are getting displayed on "Target Console" ,Since semihosting is enabled i want to know how to redirect to new console, is there any procedure to follow for semihosting. Kindly provide the details
  • Hi anandu  and welcome to the Community!
    I have moved your question to Software Development Tools where I think someone should be able to help.
  • Is your question generic, or specific for Cortex A9 and DS5?
    Generally speaking, semihosting requires good support from the debugger and means more then printing trace messages, it provides the application a method to access part of the environment available on the host. A typical application is to run unit tests, that return an exit code and create an XML file with the test results.
    I have no experience with DS5, but another environment with very good support for semihosting is SEGGER J-Link + GDB Server + GNU ARM Eclipse.
  • Where do you want the semihosted output to go?
    If you launch the model separately, and then connect DS-5, the semihosted output goes to stdout.  Would that help?
    Alternatively, the A9 FVP includes a UART model.  You could retarget fputc() to output to the UART.  The UART model opens a telnet port to handle input/output, which you could connect to.
