DS5 code execution in RAM problem... again?
VERSION: ARM DS-5 v5.24.0
In the older version ARM DS-5 v5.23.1,  I was able to push a block of executable code to 0xC0000000 using the Base_AEMv8A->Bare Metal Debug->Debug ARMAEMv8-A
target.  I could write a blob of assembly and BLR X0 <- X0 = 0xC0000000.
This worked just fine.
Now it's attempting to branch and causing an exception.
Last time (previous version), I had to hunt down the documentation (which is a nightmare to find) and locate the memory map.  Is 0xC0000000 no longer mapped to SRAM?
Thanks,
geno
  • Connecting to the model without any code loaded, I have no issues accessing 0xc0000000 (at any exception level (EL).
    I did a very quick test, loading the startup example provided, and after running through the init code, I then see 0xC0000000 is a valid address for EL3, but not for EL1N. I've not yet had a chance to work through the startup code to reason why.
    0x80000000 - 0xbfffffff seems valid for EL1N.
