IAR Embedded Workbench ARM compiler
Hi, I'm using IAR Embedded Workbench ARM are: being int a; and unsigned char b = 0x03; a = ~ b; should not be 0xfc and not 0xfffffffc? Is this a bug or is it deliberate?
  • Hi,
    as the results, the compiler is right.
    Because the operations are performed with the type matching,
    a = ~b;
    is identical to
    a = (int)~b; .
    Also,
    a = (int)~b;
    means
    if(~b[7]==1) a = {0xffffff, ~b[7:0]};
    else         a = {0x000000, ~b[7:0]}; .
    If you want to put 0xfc into the variable a, you should write as the following.
    a = (unsigned char)~b;
    Best regards,
    Yasuhiko Koumoto.
  • Hi,
    a = ~b;
    is identical to
    a = (int)~b; .
    Also,
    a = (int)~b;
    means
    Best regards,
    Yasuhiko Koumoto.
