DS-5 Debug hardware Config - Auto Configure fail!
Hi everyone,
When I am auto configuring my custom platform, DS-5 is able to see all the ARM chain like this:
-In info dialogue:
info: Opening the debug pre-connection to device 1
info: Powering up the DAP
info: Connecting to the DAP
info: Detecting AP buses
info: DAP_CONFIG_INFO = 1,00:H
info: Found AHB-AP on AP0
info: Looking for ROM tables on AP 0
info: Reading ROM table for AHB-AP at AP index 0 :-
info: ROM table base address = 0xE00FF000
info: End of ROM table
info: No platforms found that match
The following information shows the logging output when connecting to an RVI unit and autconfiguring :rvi_lob_client.exe
Connected. Now building process list, please wait...
Process List built. Connected and waiting for logging.
fpgad          warning  No connection specified to disable.
traced         error    Probe error: No supported trace connector
rifsd          error    CRIFSCmdProc::CommandFILEOPEN open failed file(/real-ice
/backup/_version_) errno=2 {No such file or directory}
serverd        warning  CArmDP_TPlateV2::SetIgnorePowerUpFail: has been configur
ed to ignore a power up failure
serverd        error    AP is disabled [AP.CSW=00000000]
serverd        error    LastErr[0] +++ AP_AxB_ReadMemBlock failed - DAP error.
serverd        error    Failed to read memory
serverd        error    DAPERR_AP_DISABLED : AP disabled - memory operation cann
ot continue.
ot continue.
usbd           error    CUsbServer: run in read error no 14
usbd           error    CUsbWriter: run Z thread exception -> Operation interrup
ted
ted
serverd        info     /var/expbus_version_info does not exist
cfgqueryd      info     DSPROBE setting: Enabling ARM JTAG 20 (PIN_MODE = JTAG)
cfgqueryd      info     Activated debug connector 1
cfgqueryd      info     CJTAGDriver::DetectRTCLK did detect RTCLK
cfgqueryd      info     CFPGA_RVIHW::SetJTAGClock @ 50000000 Hz, using RTCK
cfgqueryd      info     CClkCtrl::SetJTAGClkFreq requested freq=50000000; using
freq=100000000 with FPGADiv=0
cfgqueryd      info     CRVIAutoDetect::MeasureDeviceCount measuring the length
of DR chain in BYPASS
cfgqueryd      info     DR Chain 0..01..1 filled[1024]: 000000000000000000000000
00000000000000000000000000000000000000000000000000000000000000000000000000000000
00000001111111111111111111111111111111111111111111111111111111111111111111111111
11111111111111111111111111111111111111111111111111111111111111111111111111111111
1111111111111111111111111111111111111110
cfgqueryd      info     CRVIAutoDetect::MeasureTotalDRLength Measured total DR l
ength as 1
cfgqueryd      info     CRVIAutoDetect::MeasureDeviceCount Measured JTAG device
count as 1
cfgqueryd      info     DR Chain after tap reset[32]: 00001011101000000001010001
110111
cfgqueryd      info     Device 0 has IDCODE = 0x0BA01477
cfgqueryd      info     CRVIAutoDetect::deviceCountForIDCode device count for ID
0x0BA01477 is 1
cfgqueryd      info     CRVIAutoDetect::MeasureScanChainLength returned 1 device
s
cfgqueryd      info     CRVIAutoDetect::autodetect_config measuring the total IR
length
cfgqueryd      info     IR Chain 1..10..0 filled[1024]: 111111111111111111111111
11110000000000000000000000000000000000000000000000000000000000000000000000000000
0000000000000000000000000000000000000001
cfgqueryd      info     CRVIAutoDetect::MeasureTotalIRLength Measured total IR l
ength as 4
cfgqueryd      info     CRVIAutoDetect::autodetect_config measured the total IR
length = 4
cfgqueryd      info     CRVIAutoDetect::autodetect_config measuring the number o
f taps
ength as 1
count as 1
110111
cfgqueryd      info     AutoDetect: get_ir_data, Dev 0 IRLen=4
cfgqueryd      info     CRVIAutoDetect::autodetect_config measured the number of
taps = 1
cfgqueryd      info     Device 0 detected as ARMCS-DP from ARM
ength as 1
cfgqueryd      info     CRVIAutoDetect::get_scan_chain_length Detecting length o
f scan chain 6
ength as 1
serverd        info     CFPGA_RVIHW::SetJTAGClock @ 50000000 Hz, using RTCK
serverd        info     CClkCtrl::SetJTAGClkFreq requested freq=50000000; using
serverd        info     DSPROBE setting: Enabling ARM JTAG 20 (PIN_MODE = JTAG)
serverd        info     Activated debug connector 1
serverd        info     Performing a TAP reset on init connect
serverd        info     Selected DP TTAP path: /real-ice/jtag-templates/arm/armj
tagdp/V1.0/
serverd        info     CTurboTAPExt: Using template '/real-ice/jtag-templates/a
rm/armjtagdp/V1.0/'
serverd        info     CTurboTAPExt: Using fixed-up turbotap files
serverd        info     CFPGA_RVIHW: Verified load of TurboTAP sequence file at
1:0x0000..0x1747
serverd        info     CArmDP_TPlateV2::DAPPowerControl: Starting Power Up sequ
ence
serverd        info     DP_PowerUp - Powering up the DAP
serverd        info     CArmDP_TPlateV2::DAPPowerControl: reading 1st AP IDR to
check power up successful
serverd        info     Determined AP type as AP_AHB_SWIFT
serverd        info     CArmDP_TPlateV2::DAPPowerControl: power up complete
serverd        info     rvmsgapi: TPlateConnect() -> 0x0000, Proc ID = 0xba01477
, RVM_CONSTATE=0x000A, TAPRstOnFirstConn = true
serverd        info     CArmDP_TPlateV2::DAPPowerControl: Starting Power down se
quence
serverd        info     DP_PowerDown - Powering down the DAP
serverd        info     CArmDP_TPlateV2::DAPPowerControl: Power down sequence co
mplete
- However I can download .axf in debug Configuration for debugging. But I don't understand how the chain doesn't show up. I am new to DS-5 and FPGA, so many thank to help me understand and fix this problem!
  • Hi,
    Sorry to hear about the problems that you have been having with the configuration of your target using the Dbghw_config tool.
    From your information, I can see that :
    - a DAP (Debug Access Port) has been correctly identified
    - there is 1 Access Port, AHB-AP on AP0
    - there is a CoreSight ROM table apparently located at 0xE00FF000
    - but the reading of the CoreSight ROM table fails
    So it's the failure to read the CoreSight ROM table that is causing your target not to be detected because the tools can't determine what devices are on the target.
    I can work out that your target is a Cortex-M processor, but as the CoreSight ROM table read is apparently failing, the topology cannot be determined.
    The Dbghw_config tool is actually deprecated in DS-5 and has been replaced by the Platform Configuration Editor (PCE) from DS-5 v5.21 onwards.
    Can I suggest that you try using PCE to auto-detect the target and determine its' topology ?
    You can find a guide on how to do this at :
    Developer Resources / Tutorials / SoC Bring-Up Using the Platform Configuration Editor (PCE) | ARM DS-5 Development Stu…
    Please work through this and let me know what your results are.
    For reference, I have done the same with a known working Cortex-M3 platform and I have attached a couple of screenshots from DS-5 v5.23.1 PCE below :
    The screenshot below shows the detail of the read of the CoreSight ROM table. This may be useful for debugging the issue on your platform.
    You can see that the individual CoreSight ROM table entries that are valid (bit[0] = b1) are listed and then PCE will go to each of the address offsets listed as 'valid' and then perform a memory read to determine the devices located there.
    Once the devices have been completed, it will then attempt to determine the the topology of the platform.
    So please try PCE and let us know how you get on.
    I look forward to hearing from you.
    Regards,
    Stuart
  • Hi,
    Regards,
    Stuart
