I am unable to get trace data using trace dump command in DS-5. I'm using ARM FVP Cortex A8 Bare Metal Debug. I can get traces just fine, but I'm not able to export it to a file using trace dump.
I get following in commands window.
Writing trace dump from trace capture device FMTrace.
ERROR(ECMD3): Failed to get 1,048,576 bytes of trace data
Any Ideas?
Hi Mark,
I think you are using an older version of DS-5.
If i try the same with the latest version of DS-5 (v5.23.1) then
i) there is no FVP Cortex-A8 model included, and
ii) dumping trace from the FVP VE Cortex-A9-x4 works fine and I get :
wait
continue
interrupt
Execution stopped in SYS mode at S:0x80000740
On core ARM_Cortex-A9MP_0 (ID 0)
In primes.c
S:0x80000740 147,35 for( i=0; i <= 100000; i++) { __nop(); }
trace dump c:\temp\A9x4_FVP_trace
Writing trace dump to c:\temp\A9x4_FVP_trace
trace dump complete
According to the DS-5 changelog at http://ds.arm.com/developer-resources/ds-5-development-studio-changelog/ the Cortex-A8 FVP was removed in v5.22, so I think you are using v5.21 or earlier.
If you try upgrading to the latest version of DS-5 then everything should be fine.
I hope that helps ?
Regards,
Stuart
