Can we build EFI applications with UDK14/UDK15 targeted to AARCH64 using Visual 2012/2015/WinDDK8.1 ARM Compiler in windows platform?
I have tried building the UDK 14/15 code using VS2012 ARM Compiler and I am receiving __rd_udiv,__rt_udiv64 kind of linker errors in the UDK code.These errors I am not facing with other compilers such as GCC for ARM or x64 VS12/15 compiler.
Thanks in advance!
UDK14/UDK15 packages are provided by Intel. At the moment they tend to strip ARM packages from their deliverables. ARM packages provide 'compiler intrinsics': edk2/ArmPkg/Library/CompilerIntrinsicsLib at master · tianocore/edk2 · GitHub
I would advise you to use the Open-Source repository (https://github.com/tianocore/edk2) to build with ARM compiler(s).
If you have any build error then send an email to edk2-devel@lists.01.org.
