How to count cycles on ARM cortex m0+?
Hi
I'm new to to ARM and am working on FRDM25Z board. I would like to calculate the timing for a simple blinking program using Kinetis Studio, but my calculations does not fit my oscilloscope output.
Here is my c program:
#include "MKL25Z4.h"
static int i = 0;
int main(void)
SIM_SCGC5 |=0x400; //enable clock to port B
PORTB_PCR19 = 0x100; //Make PTB19 as GPIO
GPIOB_PDDR|=0x80000; //Make BTB19 as output pin
while(1)
  GPIOB_PDOR &= ~0x80000; //turn green led on
  GPIOB_PDOR |= 0x80000;
This compiles to:
int main(void)
51c: b580       push {r7, lr}
51e: af00       add r7, sp, #0
C:\Users\baldurtho\workspace.kds\TestProject_005\Debug/../Sources/main.c:57
//PORT B Data direction register
#define GPIOB_PDDR (*(volatile unsigned int*)0x400FF054)
//PortB Data output register
#define GPIOB_PDOR (*((volatile unsigned int*)0x400FF040))
520: 4a10       ldr r2, [pc, #64] ; (564 <main+0x48>)
522: 4910       ldr r1, [pc, #64] ; (564 <main+0x48>)
524: 4b10       ldr r3, [pc, #64] ; (568 <main+0x4c>)
526: 58cb       ldr r3, [r1, r3]
528: 2180       movs r1, #128 ; 0x80
52a: 00c9       lsls r1, r1, #3
52c: 4319       orrs r1, r3
52e: 4b0e       ldr r3, [pc, #56] ; (568 <main+0x4c>)
530: 50d1       str r1, [r2, r3]
C:\Users\baldurtho\workspace.kds\TestProject_005\Debug/../Sources/main.c:58
532: 4b0e       ldr r3, [pc, #56] ; (56c <main+0x50>)
534: 2280       movs r2, #128 ; 0x80
536: 0052       lsls r2, r2, #1
538: 64da       str r2, [r3, #76] ; 0x4c
C:\Users\baldurtho\workspace.kds\TestProject_005\Debug/../Sources/main.c:59
53a: 4b0d       ldr r3, [pc, #52] ; (570 <main+0x54>)
53c: 4a0c       ldr r2, [pc, #48] ; (570 <main+0x54>)
53e: 6952       ldr r2, [r2, #20]
540: 2180       movs r1, #128 ; 0x80
542: 0309       lsls r1, r1, #12
544: 430a       orrs r2, r1
546: 615a       str r2, [r3, #20]
C:\Users\baldurtho\workspace.kds\TestProject_005\Debug/../Sources/main.c:62 (discriminator 1)
while(1)
548: 4b09       ldr r3, [pc, #36] ; (570 <main+0x54>) <baldur: 2 cycles>
54a: 4a09       ldr r2, [pc, #36] ; (570 <main+0x54>) <baldur: 2 cycles>
54c: 6811       ldr r1, [r2, #0]                                      <baldur: 2 cycles>
54e: 4a09       ldr r2, [pc, #36] ; (574 <main+0x58>) <baldur: 2 cycles>
550: 400a       ands r2, r1                                         <baldur: 1 cycle>
552: 601a       str r2, [r3, #0]                                     <baldur: 2 cycles>
C:\Users\baldurtho\workspace.kds\TestProject_005\Debug/../Sources/main.c:64 (discriminator 1)
//Delay_ms(500);
554: 4b06       ldr r3, [pc, #24] ; (570 <main+0x54>)  <baldur: 2 cycles>
556: 4a06       ldr r2, [pc, #24] ; (570 <main+0x54>)   <baldur: 2 cycles>
558: 6812       ldr r2, [r2, #0]                                        <baldur: 2 cycles>
55a: 2180       movs r1, #128 ; 0x80                           <baldur: 1 cycle>
55c: 0309       lsls r1, r1, #12                                       <baldur: 1 cycle>
55e: 430a       orrs r2, r1                                            <baldur: 1 cycle>
560: 601a       str r2, [r3, #0]                                       <baldur: 2 cycles>
C:\Users\baldurtho\workspace.kds\TestProject_005\Debug/../Sources/main.c:66 (discriminator 1)
//Delay_ms(500);
562: e7f1       b.n 548 <main+0x2c>                             <baldur: 1/3 cycles>
564: 40047000 .word 0x40047000
568: 00001038 .word 0x00001038
56c: 4004a000 .word 0x4004a000
570: 400ff040 .word 0x400ff040 (address of portB on APB bus)
574: fff7ffff .word 0xfff7ffff (=~0x80000)
I have difficulties finding in the startup code what clock frequency I have. I checked by adding 10 "nop" commands.
(this was another strange thing: I found on the net that to dot "nop" I could do: __asm("mov r0,r0");, in C.
Strangely enough this was compiled to adds r0, r0, #0 !!!)
I got 477ns delay so each clock cycle is 4.77ns
( I made one project with processor expert (where I can read the clock on the processor component) and found that by default the clock is 32768x640=20.97MHz and this confirms my clock)
Here comes my problem: when I look at the signal on the scope it is 717 ns high and 618ns low. This would mean 717/47.7=15 clock cycles high and 618/47.7=13 clock cycles low.
But if I count (see above in <> brackets), and I expect the pin to flip on addresses 552 and 560 (the str command) I get 11 cycles low (missing 2 counts) and 14 counts high (assuming 3 clock cycle for branch back) (missing 1 count).
I have read that the pipeline for m0+ is two long so branching might explain the one missing on high side but what explains the two missing on the low side?
I would be happy for any comment, best regards,
Baldur
