terminal_0: Listening for serial connection on port 5000
Error: REMOTE_CONNECTION.CADIServer: error: failed to get CADI interface for target 0
RegisterSimulation() call of plugin instance "REMOTE_CONNECTION.CADIServer" returned error CADI_STATUS_GeneralError.
Error in plugin detected, aborting.
Error: No License found:
ERROR: License check failed!
No licenses 'RTSM_Pool_Pro' available.
Hostid doesn't match license.
License files searched:
/home/paulc/DS-5-Workspace/license.lic
terminal_1: Listening for serial connection on port 5001
Error Code : -9
terminal_2: Listening for serial connection on port 5002
terminal_3: Listening for serial connection on port 5003
Fatal Error: Call of CADISimulationFactory::Instantiate(..) did not return a CADISimulation.
SimulationEngine::simExecPort_stopAndFatalError(Failed to register all plugins);
Simulation is terminating. Reason: Simulation requested shutdown
Ok, thanks very much for letting us know.
The license error that I have fixed now, It's that I have rehost the MAC address for a request of ARM official.
Thanks for your reply again!
Which FVP/Fast Model are you trying to run, and are you trying to run it on the same PC as DS-5 ?
If the license is node-locked (and it looks like it is) then you will have to run them on the same PC, as the license will be locked to that PC.
Regards,
Stuart
paulc@ubuntu14:~$ cat /home/paulc/.flexlmrc
ARMLMD_LICENSE_FILE=/home/paulc/DS-5-Workspace/license.lic
