Help installing Fast Model Simulation
Hi, I am Trying to instal FastModelsPortfolio_9.3 I am getting the following error. Could you please help me in this regards.
"Cannot create component 'FVP_VE_Cortex_A15x1': Error creating subcomponent 'daughterboard' of type 'VEDaughterBoard' : no model found Error creating subcomponent 'motherboard' of type 'VEMotherBoard' : no model found Error creating connection 'daughterboard.cpu_clk=>cluster.clk_in': Master component 'daughterboard' is not found.  Error creating connection 'cluster.pvbus_m0=>daughterboard.cpu_pvbus': Slave component 'daughterboard' is not found.  Error creating connection 'daughterboard.cpu_irqs=>cluster.irqs': Master component 'daughterboard' is not found.  Error creating connection 'motherboard.masterclk=>daughterboard.clk_in': Master component 'motherboard' is not found. Slave component 'daughterboard' is not found.  Error creating connection 'motherboard.interrupts=>daughterboard.interrupts': Master component 'motherboard' is not found. Slave component 'daughterboard' is not found.  Error creating connection 'daughterboard.smb_cs=>motherboard.smb_cs': Master component 'daughterboard' is not found. Slave component 'motherboard' is not found.  Error creating connection 'motherboard.clcd_pvbus=>daughterboard.clcd_pvbus': Master component 'motherboard' is not found. Slave component 'daughterboard' is not found.  Error creating connection 'daughterboard.mmb=>motherboard.mmb_db1': Master component 'daughterboard' is not found. Slave component 'motherboard' is not found.  Error creating connection 'motherboard.CB[0]=>daughterboard.CB': Master component 'motherboard' is not found. Slave component 'daughterboard' is not found.  Error creating connection 'cluster.ticks=>motherboard.cluster0_ticks': Slave component 'motherboard' is not found.  Error creating connection 'motherboard.virtio_m=>cluster.acp_s': Master component 'motherboard' is not found.  Error creating connection 'motherboard.system_reset=>cluster.reset[0]': Master component 'motherboard' is not found.  Error creating connection 'daughterboard.cpu_clk=>globalcounter.clk_in': Master component 'daughterboard' is not found"
