void pythagoras(float *pDst, float * pSrc1, float * pSrc2, unsigned int size){ float a, b, c; if (size == 0) return; do { a = *pSrc1++; b = *pSrc2++; c = a*a + b*b; *pDst++ = sqrtf(c); } while (--size);}
pythagoras 0x00000018: CMP r3,#0 0x0000001C: BXEQ lr 0x00000020: PUSH {r4-r8,lr} 0x00000024: MOV r7,r3 0x00000028: MOV r4,r2 0x0000002C: MOV r5,r1 0x00000030: MOV r6,r0 0x00000034: VLDM r5!,{s1} 0x00000038: VLDM r4!,{s0} 0x0000003C: VMUL.F32 s1,s1,s1 0x00000040: VMLA.F32 s1,s0,s0 0x00000044: VSQRT.F32 s0,s1 0x00000048: VCMP.F32 s0,s0 0x0000004C: VMRS APSR_nzcv,FPSCR 0x00000050: BEQ pythagoras+68 ; 0x5C 0x00000054: VMOV.F32 s0,s1 0x00000058: BL pythagoras+64 ; 0x58 0x0000005C: SUBS r7,r7,#1 0x00000060: VSTM r6!,{s0} 0x00000064: BNE pythagoras+28 ; 0x34 0x00000068: POP {r4-r8,pc}
void integer_mix(unsigned int * pDst, unsigned int * pSrc1, unsigned int * pSrc2, float scalar, unsigned int size){ unsigned int ratio1 = (unsigned int) (scalar*256.0f); unsigned int ratio2 = 256-ratio1; unsigned int a, b, c; if (size == 0) return; do { a = *pSrc1++; b = *pSrc2++; c = ratio1*a + ratio2*b; c += 128; c >>= 8; *pDst++ = c; } while (--size);}
integer_mix 0x0000006C: PUSH {r4-r6} 0x00000070: VLDR s1,[pc,#220] 0x00000074: CMP r3,#0 0x00000078: VMUL.F32 s0,s0,s1 0x0000007C: VCVT.U32.F32 s0,s0 0x00000080: VMOV r12,s0 0x00000084: RSB r4,r12,#0x100 0x00000088: BEQ integer_mix+76 ; 0xB8 0x0000008C: CMN r3,#0x80000001 0x00000090: BLS integer_mix+84 ; 0xC0 0x00000094: LDR r5,[r1],#4 0x00000098: LDR r6,[r2],#4 0x0000009C: MUL r5,r12,r5 0x000000A0: MLA r5,r4,r6,r5 0x000000A4: ADD r5,r5,#0x80 0x000000A8: LSR r5,r5,#8 0x000000AC: SUBS r3,r3,#1 0x000000B0: STR r5,[r0],#4 0x000000B4: BNE integer_mix+40 ; 0x94 0x000000B8: POP {r4-r6} 0x000000BC: BX lr 0x000000C0: CMP r3,#1 0x000000C4: MOVLE r3,#1 0x000000C8: BLE integer_mix+104 ; 0xD4 0x000000CC: CMP r3,#0 0x000000D0: BLE integer_mix+76 ; 0xB8 0x000000D4: TST r3,#1 0x000000D8: SUB r1,r1,#4 0x000000DC: SUB r2,r2,#4 0x000000E0: SUB r0,r0,#4 0x000000E4: BEQ integer_mix+152 ; 0x104 0x000000E8: LDR r5,[r1,#4]! 0x000000EC: MUL r5,r5,r12 0x000000F0: LDR r6,[r2,#4]! 0x000000F4: MLA r5,r4,r6,r5 0x000000F8: ADD r5,r5,#0x80 0x000000FC: LSR r5,r5,#8 0x00000100: STR r5,[r0,#4]! 0x00000104: ASRS r3,r3,#1 0x00000108: BEQ integer_mix+76 ; 0xB8 0x0000010C: LDR r6,[r1,#4] 0x00000110: MUL r6,r6,r12 0x00000114: LDR r5,[r2,#4] 0x00000118: SUBS r3,r3,#1 0x0000011C: MLA r5,r4,r5,r6 0x00000120: ADD r5,r5,#0x80 0x00000124: LSR r5,r5,#8 0x00000128: STR r5,[r0,#4] 0x0000012C: LDR r5,[r1,#8]! 0x00000130: MUL r5,r5,r12 0x00000134: LDR r6,[r2,#8]! 0x00000138: MLA r5,r4,r6,r5 0x0000013C: ADD r5,r5,#0x80 0x00000140: LSR r5,r5,#8 0x00000144: STR r5,[r0,#8]! 0x00000148: BNE integer_mix+160 ; 0x10C 0x0000014C: POP {r4-r6} 0x00000150: BX lr 0x00000154: DCD 0x43800000
