DSP concept guys say, that it's time to use ARM Cortex-M microcontrollers for embedded DSP systems, so I looked at CMSIS library of filtering functions, and found that it is of block type.
As you know, the most painful feature of ARM Cortex-M architecture is the lack of circular buffer addressing mode.
I cannot find an example of this functions application for continuous, real-time signal, because, as I guess, there is a big problem of input samples block gathering in a structure compatible with CMSIS FIR function. This should be done by a DMA controller, as we don't want to loose core clock, and this task is not easy. CMSIS FIR functions has internal state buffer which length equals to block_size+numOfTaps-1.
The function in multiple steps (=block_size/4) makes 4 samples copy from input buffer to state buffer (using core !!!), but after that, before next input block filtering the last numOfTaps-1 samples in state buffer must be moved to the beginning of this buffer.
It looks bad.
Maybe someone of you solved this problem and used this function in a real-time so, please, write me about that.
Kind regards
Roman Rumian
Hi Roman,
The CMSIS DSP FIR functions are designed for block-based operation with real-time signals. The function accepts pointers to a buffer of input samples and generates a buffer of output samples. You are right that the Cortex-M lacks circularly addressing. To mitigate this issue the function was written to use a FIFO rather than a circular buffer. Once per block, the data in the FIFO is shifted by blockSize samples. This requires that we read and write N words where N is the length of the filter. The overhead is roughly N/blockSize operations per sample. The function does all of the shifting of the FIFO data and accepts a continuous stream of input blocks.
-Paul
Hello, i could implement it in real time!!! i found the right way.
Kind Regards
Any insight you could provide to that end, instead of just stating it works?
Here is a simple pin-pong buffer example using a biquad. The filter is generated from ASN DSP Filter Designer, and adopted to use ping-pong buffer in real-time:
// ** Primary Filter (H1)** ////Band# Frequencies (kHz) Att/Ripple (dB) // 1 0.000, 2.400 0.001 // 2 12.000, 24.000 80.000 //// // Arithmetic = 'Floating Point (Single Precision)'; // Architecture = 'IIR'; // Structure = 'Direct Form II Transposed'; // Response = 'Lowpass'; // Method = 'Butterworth'; // Biquad = 'Yes'; // Stable = 'Yes'; // Fs = 48.0000; //kHz // Filter Order = 8; // Included Headers #include "SMM_MPS2.h" // MPS2 FPGA board #define ARM_MATH_CM4 // Cortex-M4 (default) #include "arm_math.h" // CMSIS-DSP library header extern uint8_t audio_init(void); // Initialize audio hardware extern void read_sample(int16_t *left, int16_t *right); extern void play_sample(int16_t *left, int16_t *right); #define BLOCKSIZE 32 #define NUM_SECTIONS_IIR 4 // ** IIR Direct Form II Transposed Biquad Implementation ** // y[n] = b0 * x[n] + w1 // w1 = b1 * x[n] + a1 * y[n] + w2 // w2 = b2 * x[n] + a2 * y[n] // IIR Coefficients float32_t iirStatesf32[NUM_SECTIONS_IIR*5]; float32_t iirCoeffsf32[NUM_SECTIONS_IIR*5] = {// b0, b1, b2, a1, a2 // 48KHz sampling 0.0651210, 0.1302419, 0.0651210, 1.0463270, -0.2788444, 0.0649572, 0.1299143, 0.0649572, 1.1071010, -0.3531238, 0.0660114, 0.1320228, 0.0660114, 1.2402050, -0.5158056, 0.0721109, 0.1442218, 0.0721109, 1.4713260, -0.7982877 }; arm_biquad_cascade_df2T_instance_f32 S; // Samples from both audio channels int16_t left_channel_in; int16_t right_channel_in; int16_t left_channel_out; int16_t right_channel_out; // Ping-pong buffer float32_t InputValues_A[BLOCKSIZE]; float32_t OutputValues_A[BLOCKSIZE]; float32_t InputValues_B[BLOCKSIZE]; float32_t OutputValues_B[BLOCKSIZE]; volatile int PingPongState=0; // 0 = processing A, I/O = B // 1 = processing B, I/O = A volatile int Block_Counter=0; // Count sample from 0 to BLOCKSIZE-1, // then trigger processing and return to 0 volatile int processing_trigger=0; // When set to 1, start processing // Set to 2 during processor, return to 0 when processing is done int main(void) { int i; // Initialize data in ping-pong buffer for (i=0;i<BLOCKSIZE;i++) { InputValues_A[i] = 0.0f; OutputValues_A[i] = 0.0f; InputValues_B[i] = 0.0f; OutputValues_B[i] = 0.0f; } // Initialise Biquads arm_biquad_cascade_df2T_init_f32 (&S, NUM_SECTIONS_IIR, &(iirCoeffsf32[0]), &(iirStatesf32[0])); audio_init(); // Initialise the audio inteface // Wait for I2S IRQs to occur and service them. // allows to save power in the meantime while(1){ if (processing_trigger>0) { processing_trigger=2; // indicates biquad is running if (PingPongState==0) { arm_biquad_cascade_df2T_f32 (&S, &InputValues_A[0], &OutputValues_A[0], BLOCKSIZE); // perform filtering } else { arm_biquad_cascade_df2T_f32 (&S, &InputValues_B[0], &OutputValues_B[0], BLOCKSIZE); // perform filtering } // endif-if (PingPongState==0) processing_trigger=0; // return to 0 } // end-if (processing_trigger!=0) __WFE(); // sleep while nothing is need to be sone } } /************************************************************************/ /* I2S audio IRQ handler. Triggers at 48KHz. */ /************************************************************************/ void I2S_Handler(void) { int local_Block_Counter; // Block_Counter counts from 0 to BLOCKSIZE-1 local_Block_Counter = Block_Counter; // Read sample from ADC read_sample(&left_channel_in, &right_channel_in); if (PingPongState==0) { InputValues_B[local_Block_Counter] = (float) left_channel_in; left_channel_out=(int) OutputValues_B[local_Block_Counter]; } else { InputValues_A[local_Block_Counter] = (float) left_channel_in; left_channel_out=(int) OutputValues_A[local_Block_Counter]; } right_channel_out = right_channel_in; // Only left channel is processed // Write sample to DAC play_sample(&left_channel_out, &right_channel_out); local_Block_Counter++; if (local_Block_Counter>=BLOCKSIZE) { // Wrap around and toggle ping-pong buffer local_Block_Counter = 0; PingPongState = (PingPongState+1) & 0x1; // toggle state if (processing_trigger==2) { // Biquad is still running - overrun __BKPT(1); // Error } else { processing_trigger = 1; // Start new biquad } } Block_Counter = local_Block_Counter; // save new Block_Counter return; }
Hope this helps.
regards,
Joseph
