Snapshot viewer - updates for ini file format
I'm trying to use DS-5 (version v5.22.0) GUI software to view snapshots. I suspect the documentation needed to do so is missing  I use the Snapshot Viewer capability of DS-5 to connect to the snapshot.ini file.   When I try to connect to the snapshot.ini file, I get an error "missing required section [snapshot]".  In addition to the documented sections of a .ini file ( [global], [core], [dump], [regs] ), I needed to include an undocumented section ( [snapshot] ).  Once i added that section,  I got past the initial error but I got other errors indicating I needed further undocumented sections.  What I'm thinking is there should be an update to the docs.  The update will probably list further sections that must be provided in the .ini file.  Does anyone know where the new docs are, or have an example file showing the  new sections?  Thanks in advance
