The same instruction,realview compile correct, but arm-gcc compile get error!
Note: This was originally posted on 24th July 2012 at http://forums.arm.com
Hi all
     The instruction VSUBL Q3.S16, D0.U8, D2.U8 compiler correctly use realview, but when use arm-gcc ,get error:  "neonAsm.s:13: Error: inconsistent types in Neon instruction -- `vsubl Q3.S16,D0.U8,D2.U8' "
  • Note: This was originally posted on 25th July 2012 at http://forums.arm.com
    Hi isogen74
       Thank you for reply.    The problem is solved when use the instruction as you say!        I used to use the datasize just after the instruction, but i see the openmax's assembly file use the datasize after register.
    Hi isogen74
