arm-none-eabi-gcc -v
Using built-in specs.COLLECT_GCC=arm-none-eabi-gccCOLLECT_LTO_WRAPPER=c:/codesourcery/bin/../libexec/gcc/arm-none-eabi/4.5.2/lto-wrapper.exeTarget: arm-none-eabiConfigured with: /scratch/janisjo/arm-eabi-lite/src/gcc-4.5-2011.03/configure --build=i686-pc-linux-gnu --host=i686-mingw32 --target=arm-none-eabi --enable-threads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --enable-extra-sgxxlite-multilibs --with-gnu-as --with-gnu-ld --with-specs='%{save-temps: -fverbose-asm} -D__CS_SOURCERYGXX_MAJ__=2011 -D__CS_SOURCERYGXX_MIN__=3 -D__CS_SOURCERYGXX_REV__=42 %{O2:%{!fno-remove-local-statics: -fremove-local-statics}} %{O*:%{O|O0|O1|O2|Os:;:%{!fno-remove-local-statics: -fremove-local-statics}}}' --enable-languages=c,c++ --disable-shared --enable-lto --with-newlib --with-pkgversion='Sourcery G++ Lite 2011.03-42' --with-bugurl=https://support.codesourcery.com/GNUToolchain/ --disable-nls --prefix=/opt/codesourcery --with-headers=yes --with-sysroot=/opt/codesourcery/arm-none-eabi --with-build-sysroot=/scratch/janisjo/arm-eabi-lite/install/host-i686-mingw32/arm-none-eabi --with-libiconv-prefix=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --with-gmp=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --with-mpfr=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --with-mpc=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --with-ppl=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-cloog=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --with-libelf=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --disable-libgomp --enable-poison-system-directories --with-build-time-tools=/scratch/janisjo/arm-eabi-lite/obj/tools-i686-pc-linux-gnu-2011.03-42-arm-none-eabi-i686-mingw32/arm-none-eabi/bin --with-build-time-tools=/scratch/janisjo/arm-eabi-lite/obj/tools-i686-pc-linux-gnu-2011.03-42-arm-none-eabi-i686-mingw32/arm-none-eabi/binThread model: singlegcc version 4.5.2 (Sourcery G++ Lite 2011.03-42)
[codemake[1]: Entering directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal'make[2]: Entering directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal/lpc2106-cmucam3'make -f hal.mkmake[3]: Entering directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal/lpc2106-cmucam3'arm-none-eabi-gcc -c -o rdcf2.o rdcf2.c -I./../../include -O2 -pipe -funit-at-a-time -Wall -Wstrict-prototypes -Wcast-align -Wcast-qual -Wimplicit -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wswitch -Wno-redundant-decls -Wreturn-type -Wshadow -Wstrict-prototypes -Wunused -Wextra -Werror-implicit-function-declaration -ffreestanding -std=gnu99 -g -fdata-sections -ffunction-sections -mcpu=arm7tdmi-s -msoft-float -mthumb-interworkrdcf2.c: In function 'spec_to_name_extension':rdcf2.c:302:2: warning: pointer targets in return differ in signednessrdcf2.c: In function 'find_file':rdcf2.c:504:3: warning: pointer targets in passing argument 3 of 'spec_to_name_extension' differ in signednessrdcf2.c:286:20: note: expected 'const uint8_t *' but argument is of type 'constchar *'rdcf2.c: In function 'rdcf_rename':rdcf2.c:719:2: warning: pointer targets in passing argument 3 of 'spec_to_name_extension' differ in signednessrdcf2.c:286:20: note: expected 'const uint8_t *' but argument is of type 'constchar *'rdcf2.c: In function 'rdcf_read':rdcf2.c:795:49: error: 'EBADFD' undeclared (first use in this function)rdcf2.c:795:49: note: each undeclared identifier is reported only once for eachfunction it appears inrdcf2.c: In function 'real_rdcf_write':rdcf2.c:848:23: warning: pointer targets in initialization differ in signednessrdcf2.c:851:50: error: 'EBADFD' undeclared (first use in this function)rdcf2.c:870:4: warning: pointer targets in passing argument 3 of 'write_sector'differ in signednessrdcf2.c:147:13: note: expected 'const uint8_t *' but argument is of type 'constchar *'make[3]: *** [rdcf2.o] Error 1make[3]: Leaving directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal/lpc2106-cmucam3'make[2]: *** [hal] Error 2make[2]: Leaving directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal/lpc2106-cmucam3'make[1]: *** [all] Error 2make[1]: Leaving directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal'make: *** [all] Error 2
