Can not get Codesourcery work
Note: This was originally posted on 21st August 2011 at http://forums.arm.com
Hi everyone,
I am new to this forum as well as new to ARM development.
I have lpc2106 and I have some example projects from cmucam3 and WinARM. I wanted to compile the programs.
So, I installed cygwin and latest version of Codesourcery Lite for windows. I have installed both of them.Then I tried to test my installation by arm-none-eabi-gcc -v and the output is Using built-in specs.
COLLECT_GCC=arm-none-eabi-gcc
COLLECT_LTO_WRAPPER=c:/codesourcery/bin/../libexec/gcc/arm-none-eabi/4.5.2/lto-w
rapper.exe
Target: arm-none-eabi
Configured with: /scratch/janisjo/arm-eabi-lite/src/gcc-4.5-2011.03/configure --
build=i686-pc-linux-gnu --host=i686-mingw32 --target=arm-none-eabi --enable-thre
ads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --enable-extra
-sgxxlite-multilibs --with-gnu-as --with-gnu-ld --with-specs='%{save-temps: -fve
rbose-asm} -D__CS_SOURCERYGXX_MAJ__=2011 -D__CS_SOURCERYGXX_MIN__=3 -D__CS_SOURC
ERYGXX_REV__=42 %{O2:%{!fno-remove-local-statics: -fremove-local-statics}} %{O*:
%{O|O0|O1|O2|Os:;:%{!fno-remove-local-statics: -fremove-local-statics}}}' --enab
le-languages=c,c++ --disable-shared --enable-lto --with-newlib --with-pkgversion
='Sourcery G++ Lite 2011.03-42' --with-bugurl=https://support.codesourcery.com/G
NUToolchain/ --disable-nls --prefix=/opt/codesourcery --with-headers=yes --with-
sysroot=/opt/codesourcery/arm-none-eabi --with-build-sysroot=/scratch/janisjo/ar
m-eabi-lite/install/host-i686-mingw32/arm-none-eabi --with-libiconv-prefix=/scra
tch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/us
r --with-gmp=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-ea
bi-i686-mingw32/usr --with-mpfr=/scratch/janisjo/arm-eabi-lite/obj/host-libs-201
1.03-42-arm-none-eabi-i686-mingw32/usr --with-mpc=/scratch/janisjo/arm-eabi-lite
/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --with-ppl=/scratch/jan
isjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mingw32/usr --wit
h-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-clo
og=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-arm-none-eabi-i686-mi
ngw32/usr --with-libelf=/scratch/janisjo/arm-eabi-lite/obj/host-libs-2011.03-42-
arm-none-eabi-i686-mingw32/usr --disable-libgomp --enable-poison-system-director
ies --with-build-time-tools=/scratch/janisjo/arm-eabi-lite/obj/tools-i686-pc-lin
ux-gnu-2011.03-42-arm-none-eabi-i686-mingw32/arm-none-eabi/bin --with-build-time
-tools=/scratch/janisjo/arm-eabi-lite/obj/tools-i686-pc-linux-gnu-2011.03-42-arm
Thread model: singlegcc version 4.5.2 (Sourcery G++ Lite 2011.03-42)
Then I tried to compile the example downloaded from cmucam.org. I navigated to projects folder and typed make clean. This command was successful. But then I gave command make and it shows as following-
[codemake[1]: Entering directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal'
make[2]: Entering directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (
trunk)/hal/lpc2106-cmucam3'
make -f hal.mk
make[3]: Entering directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal/lpc2106-cmucam3'
arm-none-eabi-gcc -c -o rdcf2.o rdcf2.c -I./../../include -O2 -pipe -funit-at-a-
time -Wall -Wstrict-prototypes -Wcast-align -Wcast-qual -Wimplicit -Wmissing-dec
larations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wswitch -Wno-re
dundant-decls -Wreturn-type -Wshadow -Wstrict-prototypes -Wunused -Wextra -Werror-implicit-function-declaration -f
freestanding -std=gnu99 -g -fdata-sections -ffunction-sections -mcpu=arm7tdmi-s -msoft-float -mthumb-interwork
rdcf2.c: In function 'spec_to_name_extension':
rdcf2.c:302:2: warning: pointer targets in return differ in signedness
rdcf2.c: In function 'find_file':
rdcf2.c:504:3: warning: pointer targets in passing argument 3 of 'spec_to_name_extension' differ in signedness
rdcf2.c:286:20: note: expected 'const uint8_t *' but argument is of type 'constchar *'
rdcf2.c: In function 'rdcf_rename':
rdcf2.c:719:2: warning: pointer targets in passing argument 3 of 'spec_to_name_extension' differ in signedness
rdcf2.c: In function 'rdcf_read':
rdcf2.c:795:49: error: 'EBADFD' undeclared (first use in this function)
rdcf2.c:795:49: note: each undeclared identifier is reported only once for each
function it appears in
rdcf2.c: In function 'real_rdcf_write':
rdcf2.c:848:23: warning: pointer targets in initialization differ in signedness
rdcf2.c:851:50: error: 'EBADFD' undeclared (first use in this function)
rdcf2.c:870:4: warning: pointer targets in passing argument 3 of 'write_sector'differ in signedness
rdcf2.c:147:13: note: expected 'const uint8_t *' but argument is of type 'constchar *'
make[3]: *** [rdcf2.o] Error 1
make[3]: Leaving directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal/lpc2106-cmucam3'
make[2]: *** [hal] Error 2
make[2]: Leaving directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal/lpc2106-cmucam3'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/cygdrive/d/arm/CMUcam3 CDROM/cmucam3_install/cc3 (trunk)/hal'make: *** [all] Error 2
And I don't understand any of this. Just understand things are going wrong.
Can you please help me. I can't figure anything out. My OS is Windows 7 and it is a 64bit version. If you need anymore information just let me know.
Please help me.
***Sorry for my bad English.
