int32x4_t pairwiseAddedOnce = vpaddlq_s16(vec);int64x2_t pairwiseAddedTwice = vpaddlq_s32(pairwiseAddedOnce);int16_t sum = (int16_t)(vgetq_lane_s64(pairwiseAddedTwice, 0) + vgetq_lane_s64(pairwiseAddedTwice, 1));
int16x4_t addedDRegisters = vadd_s16(vget_low_s16(vec), vget_high_s16(vec));int32x2_t pairwiseAddedOnce = vpaddl_s16(addedDRegisters);int64x1_t pairwiseAddedTwice = vpaddl_s32(pairwiseAddedOnce);int16_t sum = (int16_t)vget_lane_s64(pairwiseAddedTwice, 0);
int32x4_t pairwiseAddedOnce = vpaddlq_s16(vec);int64x2_t pairwiseAddedTwice = vpaddlq_s32(pairwiseAddedOnce);int32x2_t narrowed = vmovn_s64(pairwiseAddedTwice);int64x1_t pairwiseAddedThrice = vpaddl_s32(narrowed);int16_t sum = (int16_t)vget_lane_s64(pairwiseAddedThrice, 0);
Does your code included into a loop or do you need to apply the algorithm only one time ?Can you explain what you are wanting to do ?
int16_t left_sum_1 = vgetq_lane_s16(multipliedVector_1, 0);int32x4_t added32x4_1 = vpaddlq_s16(multipliedVector_1);int64x2_t added64x2_1 = vpaddlq_s32(added32x4_1);int64_t right_sum_1 = vgetq_lane_s64(added64x2_1, 0) + vgetq_lane_s64(added64x2_1, 1) - left_sum_1;
vpaddlq.s16 q1, q0 vpaddlq.s32 q0, q1 vadd.s32 d0, d0, d1
vpaddlq.s16 q1, q0 vpaddlq.s16 q3, q2 vpaddlq.s16 q5, q4 vpaddlq.s32 q0, q1 vpaddlq.s32 q2, q3 vpaddlq.s32 q4, q5 vadd.s32 d0, d0, d1 vadd.s32 d4, d4, d5 vadd.s32 d8, d8, d9
So I 'll just give you some hint that could (may be) help you. vpaddlq.s16 q1, q0 vpaddlq.s32 q0, q1 vadd.s32 d0, d0, d1This code will take 6 cyclesMost of NEON instruction take only 1 cycles. But NEON is pipelined and most of the time you can't use a destination register as a source of the next instruction.The same example doing 3 times the computation vpaddlq.s16 q1, q0 vpaddlq.s16 q3, q2 vpaddlq.s16 q5, q4 vpaddlq.s32 q0, q1 vpaddlq.s32 q2, q3 vpaddlq.s32 q4, q5 vadd.s32 d0, d0, d1 vadd.s32 d4, d4, d5 vadd.s32 d8, d8, d9will take only 9 cycles!I do not know neon intrinsic, but I'm quite sure that the performance of your code will depend of the quality of the compiler.So this is not easy to reply to your question.The shortest one (in number of instruction) should be the better if the compiler is good.
