gcc segment usage
Note: This was originally posted on 17th April 2011 at http://forums.arm.com
Hi!
With gcc, we have 4 segment:
.rodata : readonly data
.data : initialized global var
.bss : uninitialized global var
.text : assembler code source
To use ADR opcode, you have to put your data into .text segment.
For example
main:
    push {r7, lr}
    adr r0, .myString
    bl printf
    mov r0, #0
    pop {r7, pc}
.myString:
.asciz "Hello\n"
I'd like to know (to be sure in fact) if you can't write into .text segment.
Ie, you can't write into r0 after the ADR instruction !
Can anybody confirm me that .text segment is read only ?
