hi,
I want to ask a question.
How to define a macro function that can be called by C language in armasm?
I know that in GNU can be used in the following way:
.macro push_x1_x12
push x1,x2
push x3,x4
push x5,x6
push x7,x8
push x9,x10
push x11,x12
.endm
ENTRY(test)
push_x1_x12 ......ENDPROC(test)
Now in armasm, I used as follow :
MACRO
push_x1_x12
MEND
But how to expand the macro that can be called by C language??
In C language, you can define macros using the #DEFINE pre-processing command.
It will do text replacement before compiling.
Here is a documentation chapter explaining ARM Inline Assembly: ARM® Compiler armcc User Guide
Here is documentation about C preprocessor and #DEFINE: C preprocessor - Wikipedia, the free encyclopedia
#DEFINE push_x1_x12 \ __asm { \ push x1,x2 \ push x3,x4 \ push x5,x6 \ push x7,x8 \ push x9,x10 \ push x11,x12 \ }
thanks,
1、I used ARMV8 that platforms is: ARM DS-5 Documentation > ARM Compiler 6 (64-bit platforms only) > armclang Reference Guide
not armcc but armclang
2、how to expand in C language?like this:
void test_tt(void)
push_x1_x12;
3、If I want to define a macro with parameters, how to deal with it ?
Replace:
.macro cpus_tst_get_opcode, _reg0
lsl \_reg0,\_reg0,#4
lsr \_reg0,\_reg0,#24
albanrampon
2. Yes. The #define is identical to replacing the text.
3. You use parameters like for a function:
#define RADTODEG(x) ((x) * 57.29578)
and in your code
y = RADTODEG(25);
will do:
y = (25) * 57.29578;
sorry,
// define:
#define push_x1_x12 \
__asm { \
push x1,x2 \
push x3,x4 \
push x5,x6 \
push x7,x8 \
push x9,x10 \
push x11,x12 \
// call
ARM Compiler 6 Compilation error
javascript:liveAction('org.eclipse.help.ui', 'org.eclipse.help.ui.internal.ShowInTocAction', '2_4')
Oups, can you try the following?
#DEFINE push_x1_x12 __asm("push x1,x2", "push x1,x2", "push x3,x4", "push x5,x6", "push x7,x8", "push x9,x10", "push x11,x12")
6.4 Inline assembly language syntax with the __asm keyword in C and C++
The link just above also shows how to add parameters: you need to put them outside of the " " starting with #.
There are several ways of declaring assembly instructions. One at a time, or a list. And for the list, the way I explained previously with curly brackets "{}" or like strings in round brackets "()".
I am not sure why the curly brackets didn't work. It may depend on the compiler.
