DS-5 fails to load image
Using Altera DS-5
DS-5 Altera Edition
Version: 5.20.2
Build number: 5202025
Full product installation (linux, x86_64)
Java HotSpot(TM) 64-Bit Server VM, version: 1.7.0_60
Gets error while loading image.
Below marked object named armv8. My image is armv7.
Is it only name or real problem with DS-5?
Any idea how to fix?
error message:
Unable to load one or more images
Exception Stack Trace:
com.arm.imagereaders.UnrecognisedFileFormatException: not an ELF file
    at com.arm.imagereaders.elf.Elf_Ehdr.<init>(Elf_Ehdr.java:849)
    at com.arm.imagereaders.elf.ElfFileReader.getElfHeader(ElfFileReader.java:226)
    at com.arm.debug.core.imagereader.nelf.ELFFile.<init>(ELFFile.java:117)
    at com.arm.debug.core.targetabstraction.arm.v8.elf.AArch64ElfFile.<init>(AArch64ElfFile.java:144)
    at com.arm.debugger.control.ConnectionController.doPostDebugServiceInitialization(ConnectionController.java:904)
    at com.arm.debugger.control.ConnectionController.manageDebugServiceAndInitialize(ConnectionController.java:759)
    at com.arm.debugger.control.ConnectionController.doInitialize(ConnectionController.java:559)
    at com.arm.debugger.control.ConnectionController.manageThreadModelAndInitialize(ConnectionController.java:539)
    at com.arm.debugger.control.ConnectionController.manageProgressResourceAndInitialize(ConnectionController.java:484)
    at com.arm.debugger.control.ConnectionController.initialize(ConnectionController.java:432)
    at com.arm.debugger.control.ConnectionManager.createConnection(ConnectionManager.java:360)
    at com.arm.debugger.launcher.TargetLauncher.launch(TargetLauncher.java:20)
    at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:858)
    at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:707)
    at com.arm.debugger.control.VariableResolvingLaunchConfiguration.launch(VariableResolvingLaunchConfiguration.java:273)
    at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1018)
    at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1222)
    at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Session data:
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.7.0_60
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -product com.arm.ds.altera
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product com.arm.ds.altera
