armcc --via file limitation?
armcc 5.0.4.82 on Win7
When armcc links, I get the following error message (formatted by CMake/ninja)
Error: C4365E: Subtool invocation error: Command line too long
This error message is not described for armccor armlink
The command line is as follows (there are more options normally, but I get the error only with the following):
d:\ARM_Compiler_5\5.0.4.82\bin64\armcc.exe    --cpu=Cortex-A9  --via=out.rsp  -o out.elf
If the file in --via is more than about 32767 bytes, the linking fails.
The command is run from cmd.exe, but armcc should parse the --via file by itself to my knowledge.
A very temporary workaround is to move the objectfiles before linking, so the path can be shortened. Will fail again when number of files increases.
/Gerhard
