I am using DS5 v5.21.1 ultimate(Evaluation Version), I am trying to capture trace of ARM cortex A8 Fast model ("ARM FVP (Installed with DS-5) -> Cortex-A8 -> Bare Metal ->
Debug -> Debug Cortex-A8") and have also added "--plugin MTS" option in the Connections -> Bare Metal Debug -> Model parameters.
While debugging the fast model get terminated abruptly stating "Failed to capture trace. A communication error has occurred between host and trace unit"
Following are the console logs:
terminal_1: Listening for serial connection on port 5003
terminal_2: Listening for serial connection on port 5000
terminal_0: Listening for serial connection on port 5002
terminal_3: Listening for serial connection on port 5001
WARNING: baseboard.mmc: MMC backing store file mmc.dat could not be used
When loading plugin "C:\Program Files\DS-5 v5.21.1\sw\models\bin\MTS.dll":
Error loading plugin: The specified procedure could not be found.
INFO: baseboard.mmc backing store: no image file connected
CADI server started listening to port 7000
CADI server is reported on port 7000
Simulation is terminating. Reason: Simulation requested shutdown
Note:
I am runnning on a Windows XP Professional SP3 (32 bit ) Machine.
Can we capture trace of a fast model with DS5 ultimate evaluation version ?
You should be able to capture trace without having to use the --plugin MTS option now. It's enabled by default in the example programs, but not in any new projects you create. You can enable it through the DTSL Options dialog when you create a debug configuration:
Side note: support for Windows XP is now deprecated in DS-5 as described in the Change Log for v5.21: http://ds.arm.com/developer-resources/ds-5-development-studio-changelog/
Hope that helps,
Joe
