I am using DS5 v5.21.1 ultimate(Evaluation Version), I am trying to capture trace of ARM cortex A8 Fast model ("ARM FVP (Installed with DS-5) -> Cortex-A8 -> Bare Metal ->
Debug -> Debug Cortex-A8") and have also added "--plugin MTS" option in the Connections -> Bare Metal Debug -> Model parameters.
While debugging the fast model get terminated abruptly stating "Failed to capture trace. A communication error has occurred between host and trace unit"
Following are the console logs:
terminal_1: Listening for serial connection on port 5003
terminal_2: Listening for serial connection on port 5000
terminal_0: Listening for serial connection on port 5002
terminal_3: Listening for serial connection on port 5001
WARNING: baseboard.mmc: MMC backing store file mmc.dat could not be used
When loading plugin "C:\Program Files\DS-5 v5.21.1\sw\models\bin\MTS.dll":
Error loading plugin: The specified procedure could not be found.
INFO: baseboard.mmc backing store: no image file connected
CADI server started listening to port 7000
CADI server is reported on port 7000
Simulation is terminating. Reason: Simulation requested shutdown
Note:
I am runnning on a Windows XP Professional SP3 (32 bit ) Machine.
Can we capture trace of a fast model with DS5 ultimate evaluation version ?
