my_printf compiling for aarch64, armclang vs gcc
I compiled same sample c file, but got very different asmbler code.
The c file is:
void my_print(char *fmt, ...){
    *((volatile int *) 0x1000) =(int) &fmt;
void test(void){
    my_print("a", 1, 2, 3, 4, 5, 6, 7, 8, 9);
By armclang( ARM Compiler 6.01 (build 22)), command is as "armclang -mcpu=cortex-a53 --target=aarch64-arm-none-eabi test.c" , and the assemble code of my_print is like:
0000000000008000 <my_print>:
    8000:   d10303ff    sub sp, sp, #0xc0
    8004:   3d801fe7    str q7, [sp,#112]
    8008:   3d801be6    str q6, [sp,#96]
    800c:   3d8017e5    str q5, [sp,#80]
    8010:   3d8013e4    str q4, [sp,#64]
    8014:   3d800fe3    str q3, [sp,#48]
    8018:   3d800be2    str q2, [sp,#32]
    801c:   3d8007e1    str q1, [sp,#16]
    8020:   3d8003e0    str q0, [sp]
    8024:   f9005be7    str x7, [sp,#176]
    8028:   f90057e6    str x6, [sp,#168]
    802c:   f90053e5    str x5, [sp,#160]
    8030:   f9004fe4    str x4, [sp,#152]
    8034:   f9004be3    str x3, [sp,#144]
    8038:   f90047e2    str x2, [sp,#136]
    803c:   f90043e1    str x1, [sp,#128]
   8040:   f9005fe0    str x0, [sp,#184]      // Jerry: x0, i.e., the address of fmt, located at the bottom of the stack.
    8044:   9102e3e0    add x0, sp, #0xb8
    8048:   2a0003e8    mov w8, w0
    804c:   321403e9    orr w9, wzr, #0x1000
    8050:   2a0903e0    mov w0, w9
    8054:   b9000008    str w8, [x0]
    8058:   910303ff    add sp, sp, #0xc0
    805c:   d65f03c0    ret
For gcc(aarch64-none-elf-gcc, Linaro GCC 4.8.3), command as "aarch64-none-elf-gcc test.c -nostdlib", then the assemble code is like:  400024:   d10343ff    sub sp, sp, #0xd0
  400028:   f9004fe1    str x1, [sp,#152]
  40002c:   f90053e2    str x2, [sp,#160]
  400030:   f90057e3    str x3, [sp,#168]
  400034:   f9005be4    str x4, [sp,#176]
  400038:   f9005fe5    str x5, [sp,#184]
  40003c:   f90063e6    str x6, [sp,#192]
  400040:   f90067e7    str x7, [sp,#200]
  400044:   3d8007e0    str q0, [sp,#16]
  400048:   3d800be1    str q1, [sp,#32]
  40004c:   3d800fe2    str q2, [sp,#48]
  400050:   3d8013e3    str q3, [sp,#64]
  400054:   3d8017e4    str q4, [sp,#80]
  400058:   3d801be5    str q5, [sp,#96]
  40005c:   3d801fe6    str q6, [sp,#112]
  400060:   3d8023e7    str q7, [sp,#128]
  400064:   f90003e0    str x0, [sp]               // Jerry : x0, i.e., the address of fmt, located at the top of the stack.
  400068:   d2820000    mov x0, #0x1000                 // #4096
  40006c:   910003e1    mov x1, sp
  400070:   b9000001    str w1, [x0]
  400074:   910343ff    add sp, sp, #0xd0
  400078:   d65f03c0    ret
The armclang is behavior is as expected? And gcc voilated Procedure Call Standard?
B.R
Jerry
