CMSIS: DSP Lib - Frequency Bin Example (strange behavior)
Estimated colleagues,
following I explain the strange behavior:
  • I am working the STM32F407 ARM processor,
  • compiling with the GNU Tools ARM (4_9-2014q4) ,
  • use the HAL provided by STM32CubeF4 v1.5.0,
  • using the DSPLib provided CMSIS Version 1.4.4 2014/07/31 ,
  • UPDATE 2015-05-22:
    • I also tried this with the last MDK-ARM version (uVIsion V5.14.0.0) and ITS CMSIS / DSP_Lib examples and found the same effect!!
During testing my board with the "Frequency Bin Example" provided with the DSP Lib I found following effects:
A) The example test program provided by CMSIS works fine. That is testIndex equals to refIndex (which is 213) and goes to infinite loop.
B) But when I modify the program e.g. with a while() in order to execute cyclically like this
...global and extern variables...
void main(void)
  arm_status status;
  float32_t maxValue;
     while(1)
       status = ARM_MATH_SUCCESS;
       /* Process the data through the CFFT/CIFFT module */
       arm_cfft_f32(&arm_cfft_sR_f32_len1024, testInput_f32_10khz, ifftFlag, doBitReverse);
       /* Process the data through the Complex Magnitude Module for
       calculating the magnitude at each bin */
       arm_cmplx_mag_f32(testInput_f32_10khz, testOutput, fftSize);
       /* Calculates maxValue and returns corresponding BIN value */
       arm_max_f32(testOutput, fftSize, &maxValue, &testIndex);
        if(testIndex !=  refIndex)
         status = ARM_MATH_TEST_FAILURE;
the program throws ARM_MATH_TEST_FAILURE the second time.
C) If I define testInput_f32_10khz[] as a constant array on the flash then the program throws ARM_MATH_TEST_FAILURE always.
  • The problem does not have to do with the bit reversal problem of old versions (so much as I could see from other discussions).
  • I am using the sources not the library (because only the ARM library is provided with STMCube.
Hopefully someone can help me or give me some tip.
Thank you in advance!.
