Hi Experts,
I could find that the recent compiler versions uses the Clang instead of GCC in the ARM compiler.
Can I get few key points in using the Clang and getting much more benefit from it ?
Regards,
Techguyz
ARM Compiler 6 is based on LLVM and uses Clang as a front end. Although you can use GNU GCC to compile code for ARM platforms, ARM Compiler 5 is based on a proprietary code base and it has never been based on GNU GCC.
Using ARM Compiler 6 has many advantages, a few keypoints are:
You can find ARM Compiler 6 in DS-5. You can download a 30-day evaluation version from DS-5 Downloads | ARM DS-5 Development Studio.
Hope this helps!
Best Regards,Stefano
