ARM CORTEX A8 : use of fpack-struct compiler directive
Note: This was originally posted on 27th May 2009 at http://forums.arm.com
I am compiling an application with arm linux gcc version 4.2.3 (Sourcery G++ Lite 2008q1-126) with the compiler directive's.
I want to optimize this application for the ARM and I am not suppose to use DSP.
[font="Courier New"]
arm-linux-gcc ../Src/*.c ../Src/SimdFunctions.s ../Src/getRectSubPix.s -DOPT_WIN_SIZE -DENABLE_SIMD_GETRECTSUBPIX -DUSE_SIMD -DUSE_SIMD_DAVID -I ../Inc -mcpu=cortex-a8 -mfpu=neon -Wa,-mfpu=neon -mfloat-abi=softfp -o ../Obj/opt_blink.out -O3 -fpack-struct -freorder-blocks-and-partition -lm -lc -lgcc -ftree-vectorize[/font]
after compilation total number of lines of assembly code generated is 35563.
If i remove the compiler directive -fpack-struct the total number of lines of assembly code is 22354.
I checked this by writing a small C program which updates the structure that consists of 3 integer elements. consider if i want to write 55, 66, 77 to these three elements then
with -fpack-sturct directive the program uses byte store to store 55, 66, 77 and then fills the remaining bytes with zeros which generates around 20 lines of assembly code
whereas without -fpack-sturct it writes directly to the location and the assembly generated is is of about 5 lines.
Also help me in any compilation directives to be given to optimize even more.
thanks and regards
Shashi
shashi.ms@samsung.com
