Realview aligning variables
Note: This was originally posted on 22nd August 2011 at http://forums.arm.com
Hi
In Keil RealView is there some compiler or linker command switch that will ensure that all declared variables will be aligned to a 32bit boundary?
Edit: I'm using the Keil MDK toolchain, I'm not sure if this is the same as Realview. I've come across --min_array_alignment=4. I don't think its applicable to non array types. I want all types to be aligned
