Issue building demo code in Crossworks
Note: This was originally posted on 24th September 2010 at http://forums.arm.com
I recently purchased (3) LCD-DEMO-LPC2158 kits for a home project.  I am trying to compile the demo code provided by the manufacturer, FDI.  The code was compiled in version 1.7 of uVision.  When I try to compile in CrossWorks, I am getting errors.  I am currently using the 30-day trial of Crossworks, and am not sure if there are limitations on the demo application, if I need to configure the tool, or if this code is not supported.
Snippet of code failing:
void CPUDisableInterrupts(void) __arm
    __asm  {
        MRS R1, CPSR
        ORR R1,R1,#0xC0
        MSR CPSR_cxsf, R1
    return;
Errors during build:
expected declaration specifiers before '__arm'
stray '#' in program
expected '=', ',',';', 'asm' or '__attribute__' before '{' token
Any help would be greatly appreciated
  • Note: This was originally posted on 24th September 2010 at http://forums.arm.com
    By convention anything starting with "__" (double underscore) is something that is tool chain specific.  The __asm directive with armcc (the Keil/RVDS compiler) lets you include inline assembler.  It looks like the CrossWorks tools don't support __asm.  They might have an equivalent, but it would mean porting the code.
    As far as I'm aware, CrossWorks doesn't support inline assembler, though its documentation suggests that this might work:
    #include <libarm.h>
    libarm_disable_irq_fiq();
    hth
    s.
