I follow this Getting Started with ARM DS-5 Development Studio | ARM DS-5 Development Studio to run HelloWorld_FVP,
error occurs like this:
eclipse.buildId=4.3.2.M20140221-1700java.version=1.7.0_60java.vendor=Oracle CorporationBootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CNFramework arguments: -product com.arm.ds.ultevalCommand-line arguments: -os win32 -ws win32 -arch x86_64 -product com.arm.ds.ulteval
ErrorThu Mar 19 18:58:34 CST 2015Unable to connect to HelloWorld_FVP. The script file ( rtsm_launcher.py ) failed during execution:Failed to launch model FVP_EB_Cortex-A8. Command: C:\Program Files\DS-5\bin\FVP_EB_Cortex-A8.exe -S --print-port-numberexited with error code: -1073741819
See Target Console view for more details
com.arm.debugger.control.LaunchException: The script file ( rtsm_launcher.py ) failed during execution:
See Target Console view for more details at com.arm.debugger.control.target.AbstractTargetController.runSetupScript(AbstractTargetController.java:187) at com.arm.debugger.control.target.AbstractTargetController.setupTarget(AbstractTargetController.java:87) at com.arm.debugger.control.ConnectionController.doPreDebugServiceInitialization(ConnectionController.java:645) at com.arm.debugger.control.ConnectionController.doInitialize(ConnectionController.java:555) at com.arm.debugger.control.ConnectionController.manageThreadModelAndInitialize(ConnectionController.java:539) at com.arm.debugger.control.ConnectionController.manageProgressResourceAndInitialize(ConnectionController.java:484) at com.arm.debugger.control.ConnectionController.initialize(ConnectionController.java:432) at com.arm.debugger.control.ConnectionManager.createConnection(ConnectionManager.java:360) at com.arm.debugger.launcher.TargetLauncher.launch(TargetLauncher.java:20) at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:858) at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:707) at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1018) at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1222) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)Caused by: com.arm.debug.launch.script.ScriptException: The script file ( rtsm_launcher.py ) failed during execution:
Failed to launch model FVP_EB_Cortex-A8. Command: C:\Program Files\DS-5\bin\FVP_EB_Cortex-A8.exe -S --print-port-numberexited with error code: -1073741819 at com.arm.debug.launch.script.PythonScriptRunner.run(PythonScriptRunner.java:131) at com.arm.debug.launch.script.TargetControlScriptRunner.run(TargetControlScriptRunner.java:36) at com.arm.debugger.control.target.AbstractTargetController.runSetupScript(AbstractTargetController.java:184) ... 13 moreCaused by: Traceback (most recent call last): File "C:\Program Files\DS-5\sw\debugger\configdb\Scripts\rtsm_launcher.py", line 356, in <module> modelLauncher.launch() File "C:\Program Files\DS-5\sw\debugger\configdb\Scripts\rtsm_launcher.py", line 187, in launch raise RuntimeError, \RuntimeError: Failed to launch model FVP_EB_Cortex-A8. Command: C:\Program Files\DS-5\bin\FVP_EB_Cortex-A8.exe -S --print-port-numberexited with error code: -1073741819
at org.python.core.PyException.doRaise(PyException.java:200) at org.python.core.Py.makeException(Py.java:1239) at org.python.core.Py.makeException(Py.java:1243) at org.python.pycode._pyx2.launch$8(C:\Program Files\DS-5\sw\debugger\configdb\Scripts\rtsm_launcher.py:197) at org.python.pycode._pyx2.call_function(C:\Program Files\DS-5\sw\debugger\configdb\Scripts\rtsm_launcher.py) at org.python.core.PyTableCode.call(PyTableCode.java:165) at org.python.core.PyBaseCode.call(PyBaseCode.java:134) at org.python.core.PyFunction.__call__(PyFunction.java:317) at org.python.core.PyMethod.__call__(PyMethod.java:109) at org.python.pycode._pyx2.f$0(C:\Program Files\DS-5\sw\debugger\configdb\Scripts\rtsm_launcher.py:359) at org.python.pycode._pyx2.call_function(C:\Program Files\DS-5\sw\debugger\configdb\Scripts\rtsm_launcher.py) at org.python.core.PyTableCode.call(PyTableCode.java:165) at org.python.core.PyCode.call(PyCode.java:18) at org.python.core.Py.runCode(Py.java:1275) at org.python.core.__builtin__.execfile_flags(__builtin__.java:522) at org.python.util.PythonInterpreter.execfile(PythonInterpreter.java:225) at com.arm.debug.launch.script.PythonScriptRunner.run(PythonScriptRunner.java:120) ... 15 more
Any body can help me?
Looking at your error code:
-1073741819 seems to commonly relate to access violation exceptions. From looking at your command line arguments, maybe this is because you're trying to run the 64-bit version of DS-5 in 32-bit mode?
Thanks,
Joe
thks for your help, Joe
I use 64-bit version DS-5 on win7 64bit OS, why this error occurs? This is really strange.
Can you give me some suggestion?
You're welcome - we'll investigate further.
Hi,Unfortunatly i have not the chance to work on the 64bit environment
Welcome in the community.
It may be a general Eclipse issue (from not being able to locate some .dll files) according to technical support.
Try following the suggestions here: How to solve DS-5 installation issues under Windows?
Just for reference, which version of DS-5 are you using? 5.20.2 is the latest.
Hi
I had the same problem, but I found out that i just don't have FVP part for my ARM
check out .exe-files with the name FVP... in folder: ../ds-5/bin/
