Why Hard Fault for STM32?
Note: This was originally posted on 4th January 2010 at http://forums.arm.com
Hey, guys
    When I debuggig my RVMDK(ver 3.80) application of STM32 MCU with [url="http://www.coocox.org/Colink.htm"][color="#0000FF"]CooCox Colink [/color][/url],
A Hard-Fault exception was occured when runing the following code:
[color="#FF0000"]C code:[/color]
     unsigned long long *index;
     index  = (unsigned long long *)0x20000102; // non-aligned(64-bits )
     *index = 0x100;
[color="#FF0000"]the Disassembly Code:[/color]
     LDR.W  r8,[pc,#148]
     ADR    r1,{pc}+2
     LDM    r1,{r0-r1}
     STRD   r0,r1,[r8,#0] // hard-fault occur
operate a 64-bit pointer above will occur a hard-fault exception,
but operate a 32-bit pointer like following code is OK:
      unsigned int *index;
      index  = (unsigned int *)0x20000102;  // non-aligned(32-bits )
      *index = 0x100;
      LDR.W  r8,[pc,#148]
      MOVS   r0,#0x100
      STR    r0,[r8,#0x00]
I know the Cortex-M3(ARM-V7) support non-align access,
the align access of 32-bits and 64-bits is OK.
but why 32-bits non-align can pass,and 64-bits non-Align can't?
where is the difference of word and double-words access ?
Any help here is deeply appreciated!
  • Note: This was originally posted on 4th January 2010 at http://forums.arm.com
    Look at section A3.2.1 of the Architecture Reference Manual (V7M). There are still some alignment limitations.
    The following data accesses always generate an alignment fault:
    "¢ Non halfword-aligned LDREXH and STREXH
    "¢ Non word-aligned LDREX and STREX
    "¢ Non word-aligned LDRD, LDMIA, LDMDB, POP, and LDC
    "¢ Non word-aligned STRD, STMIA, STMDB, PUSH, and STC
    So your 32-bit code is OK with non-aligned pointer, but the 64-bit code is not.
